Stripped thread... advices?
Old May 2, 2011 | 11:38 PM
yunebug's Avatar
Default Stripped thread... advices?
In the middle of my tail conversion, I came across a problem.
When I put the fairing on and tried to install the frankenstein bolt on the right side, I noticed that the bolt wasn't catching on the thread. Sure enough, the hole on the subframe was mangled.
What can I do to install my frankenstein bolt? Is there a way to fill the hole, re-drill and re-tap?
Also, the Delkevic fairing from China is not an OEM fit... I suppose I should have expected that one. :0p
Buyers beware:
Honda CBR600 F4i 01-03 Tail Seat Cowl Fairing Unpainted | eBay
Old May 3, 2011 | 12:02 AM
FoCoCBR's Avatar
Its already plural.. you wouldn't say "chineses" haha I'm kidding..
Anyways, I'd run to wally world and get some loctite. I think they have one specifically for stripped threads.
Old May 3, 2011 | 12:10 AM
yunebug's Avatar
FoCo,
what's plural? Also it's spelled "it's" with an apostrophe.
I'd go with the LocTite solution, but I may want to take my faring off in the future. I would like to be able to screw on and off the frankenstein bolt.
Old May 3, 2011 | 12:25 AM
karl10250's Avatar
you try using a tap and rethreading it? that might work. but you might need something to fill the space too. you could always try the loctite idea
Old May 3, 2011 | 01:09 AM
yunebug's Avatar
Thanks for the reply Karl. I don't think a tap would work because the thread inside the hole has been ground out by the previous owner - probably didn't let the thread catch the bolt and just powered his way in.
I will definitely need to fill the space with something and re-drill / re-tap. I want to do this right. LocTite will work - problem is, if I ever want to take the fairing off, it will be impossible to take the frankenstein bolt back out again.
Hmm....
Old May 3, 2011 | 01:32 AM
rd91si's Avatar
Use jb weld drill and tap should be easy, or helicoil it.
Old May 3, 2011 | 02:12 AM
karl10250's Avatar
ahhh my old friend jb weld.. Idk if it will crack or not in this case but its worth a try if your stuck its worth a try.. maybe try drilling a hole in a block of wood or something and make sure it works first though. that would suck get some jb weld stuck in there
Old May 3, 2011 | 02:19 PM
Ragnar1x's Avatar
Originally Posted by rd91si
helicoil it
This.
Old May 3, 2011 | 02:44 PM
F34Me?'s Avatar
Originally Posted by Ragnar1x
This.
It just holds the plastic cowl on? JB will do just fine!
PS. Sorry but I meant to quote the "helicoil" part not the "this" part...
Old May 3, 2011 | 04:01 PM
cynicalrider's Avatar
Not worth helicoiling for just the fairing bolt IMO. JB weld, and tap and you are set.
