Stripped spark plug hole
Old Aug 19, 2011 | 04:23 PM
ajreyno1994's Avatar
Default Stripped spark plug hole
Well guys, went to change my plugs today and can't get #3 to tighten, my dad is working on it as we speak. If it won't tighten though, what are my options? Please help
Old Aug 19, 2011 | 04:54 PM
MadHattr059's Avatar
Heli-coil. That's what they're made to do. Go to your local auto store
and ask for a heli-coil kit. It's basically like a spring that winds into your
hole after your do a small ream on it.
HeliCoil Corporation
Good luck on that, Ern
Old Aug 19, 2011 | 05:59 PM
aurora_F4i's Avatar
Get a grade 8 bolt, the goldish one and get it lined up and try to re tap it. It will clean it up. It's much harder than the engine block.
Old Aug 19, 2011 | 06:11 PM
So I'm not totally screwed?
Old Aug 19, 2011 | 06:37 PM
gotcbr's Avatar
MadHattr059's advice is spot-on.
Old Aug 19, 2011 | 06:50 PM
aurora_F4i's Avatar
Not at all, the helio coil will work, just if you have a grade 8 bolt laying around it might do the trick.
Old Aug 19, 2011 | 07:09 PM
I don't have either. What all would the coil consist of me doing
Old Aug 19, 2011 | 09:17 PM
Soulhammer's Avatar
Heli-Coil is very simple to use, it comes with its own tap/reamer and crank, all you do is turn it in usually you go 1 turn forward half turn backwards and repeat, then theres a heli-coil install tool which threads it in and it threads off but the coil stays in place, its the best solution to stripping you can do
Old Aug 20, 2011 | 10:59 AM
boredandstroked's Avatar
Nobody is mentioning that if you do this with the head on the block then you get metal shavings in the cylinder.
Old Aug 20, 2011 | 11:17 AM
ThaBrock's Avatar
Get the piston at the top position and pick out the large pieces with a oily object (screw driver?) and the smaller pieces should blow right out the tail pipe?
