Strange Sound
Old Aug 28, 2006 | 03:52 PM
Jaybird180's Avatar
Default Strange Sound
Haven't ridden in 5 weeks. Took her out yesterday. Rode for about 15 mins and then realized that I missed my exit to my practice area. U-Turn. On the way back, I decide to hit it, 4th 5th then i get a strange sound around 7k it sounded like a rev limiter sound coming out of the exhaust. I pull over a rev. It sounds fine. I listen to intake, OK. Get back on, its doing it again 3rd and 4th gear 7-10k.
A freind says my clutch is on the way out. What do you guys think?
Old Aug 28, 2006 | 04:38 PM
Jaybird180's Avatar
Default RE: Strange Sound
I should add that it cleared up later that day and that when it did it there was power loss.
I would hate to get banked over and not have the power, or worse need to get away in traffic.
Old Aug 28, 2006 | 04:52 PM
Tahoe SC's Avatar
perhaps crap in your fuel from sitting over 5 weeks?!?
Old Aug 28, 2006 | 05:53 PM
Jaybird180's Avatar
Moisture maybe?
Old Aug 29, 2006 | 12:45 PM
Jaybird180's Avatar
Default UPDATE: Strange Sound
I took her out yesterday. Cruising at 7k. Smoothly creeping up to 7.5 the sound starts coming back. Back off it goes away. Then it hits me: "I remember hearing that sound last time I rode her hard...at the track". What did I change before the track? I put on a PowerCommander map I got from Muzzy. It sounds like its running on 2.5 cylinders. Can a poor map cause this kind of sound coming from the exhaust along with lack of power and inconsistent firing?
Old Aug 29, 2006 | 02:30 PM
Blackdog F4i's Avatar
Default RE: UPDATE: Strange Sound
Yep, it may be running too rich in that range. Rich will cause the exhaust to be a lil quieter and a power loss.
Old Aug 29, 2006 | 02:37 PM
Jaybird180's Avatar
It's same volume but sounds sick (not in a good way). I'll look at the numbers on the map, but if I recall, it's leaned out in that range. Strangely I noticed that after slowing and coming for a stop at the next light, the noise point began to move down the rev range. It went to 5.5 then 3.5 then 2k. I got to my destination, shut down and then went home with less predictible problem. Bike wasn't overheating.
Old Aug 29, 2006 | 03:36 PM
worst comes to worst, just disconnect the PC and run it without and see if you have the same issue.
Old Aug 30, 2006 | 03:43 PM
Got the map. I sent you a e-mail back.
Old Aug 30, 2006 | 04:20 PM
F1_Fan's Avatar
Have you checked the battery terminals? So often, you'll hit just the right resonance to jiggle a loose terminal. Since the F4i can't run w/o battery power you get stuttering and power loiss.
