Straight wire the fan ?
Old Aug 30, 2006 | 11:58 PM
600f4ika's Avatar
Default Straight wire the fan ?
I was thinking about straight wiring the fan to an ignition switch wire so the fan comes on with the ignition on. Which wires do I need to hook to? Also do I need to put a toggle switch in line or just straight wire it?
Old Aug 31, 2006 | 12:06 AM
woodyracing's Avatar
Default RE: Straight wire the fan ?
why?
Old Aug 31, 2006 | 12:12 AM
jimd2p's Avatar
What year is the bike?
I would definately use a relay to lighten a load. Let me know and I can try to help you with a diagram.
Old Aug 31, 2006 | 12:42 AM
DThompson's Avatar
I would just wire it to a switch instead of the ignition. Just turn it on yourself, you dont really need it when you are on the highway.
Old Aug 31, 2006 | 12:44 AM
Mike_Stunts's Avatar
i did this to my f4i stunt bike. i tapped into the tail light from the thermo. it works and will not drain the battery since the tail light is an accesorry. the only reason i did it to my stunt bike is because i dont go fast enough for air to flow through the radiator.
Old Aug 31, 2006 | 04:14 PM
Blackdog F4i's Avatar
Don't do it on a street bike. No reason to run the fan all the time. If your temp sensors are working properly the ECU will turn on the fan when you need it.
redzintimidator
How-To: Mechanical
174
Aug 8, 2014 01:07 PM
aight
May 1, 2011 02:05 PM
QB420
Jun 29, 2007 01:16 AM
ddvs
Aug 14, 2006 10:04 PM
yp_urslf
May 27, 2006 07:38 AM
