Stopped at high gear - what to do?
Old May 30, 2007 | 02:27 AM
Daffy472's Avatar
Default Stopped at high gear - what to do?
What do you do if you stopped at higher gear? Just found out that the bastarddoesn'talwayswant to downshift to 1stthat easily after that [&:]
Old May 30, 2007 | 03:07 AM
SchiraF4I's Avatar
Default RE: Stopped at high gear - what to do?
Roll it back and forth while you downshift while you are stopped
Old May 30, 2007 | 02:35 PM
2002F4!'s Avatar
ORIGINAL: SchiraF4I
WINNER!
Old May 30, 2007 | 02:44 PM
voodoochyl's Avatar
Retired Moderator
Mark it on your list of things not to do again...
Old May 30, 2007 | 03:07 PM
Daffy472's Avatar
Hehe, thanks[8D]
Old May 30, 2007 | 03:12 PM
jaynd's Avatar
yeah its the same w/ a car/truck. just gotta let it roll a slight bit then try again.
Old May 30, 2007 | 03:47 PM
f4iguy8804's Avatar
Or you can let out the clutch slowly and slightly while pushing the shifter down. - SLOWLY! SOFT!
Old May 30, 2007 | 08:55 PM
crunkchris's Avatar
you are suppossed to drop the clutch while slamming on the shifter with both feet, You'll put it in first!!! lmao
Old May 30, 2007 | 10:04 PM
1998f3's Avatar
yep, just let out the clutch a little and it'll slip down a gear. Thats what I do.
Old May 30, 2007 | 11:02 PM
FiremanE4's Avatar
This can happen in neutral also, just so you know. For example should you be sitting at a light in neutral sometimes you have to roll it a little to get it to take the gear.
