steering creaking???
Old Jan 19, 2006 | 06:18 PM
eteller's Avatar
Default steering creaking???
Hey all, I'm getting a funny creaking noise when stopping on my 2002 F4i. It's just one little creak, and i thing I can feel a little give when it occurs. I'm thinking the steering head bearings may need cranking down on a little? The triple trees and clip-ons are both tight. Anyone else have any sort of issues like this? The bike has 13K mi on it, never wrecked.
Old Jan 19, 2006 | 06:59 PM
shraz's Avatar
Default RE: steering creaking???
engine turned off
move handles left and right and see if u can spot the noise
might be something lose
last time I had my horn hanging w/ the wires lol
Old Jan 19, 2006 | 07:45 PM
Tahoe SC's Avatar
otherwise, put the bike up on tripe stands and pull the front tire in a forward backward position. if you feel some 'klunk' type give...you need to either get new bearings or tighten it up.
has it ever been wheelied or wrecked?
Old Jan 19, 2006 | 08:13 PM
billmacomber16's Avatar
I have the same thing man I don’t know what it is but I do wheelie mine a lot. Its like a drug. But yeah I don’t know what it is I thought head set too but I haven’t messed with any thing yet
Old Jan 19, 2006 | 09:17 PM
pitsvtec's Avatar
Can you use a lubricant to delete the problem? (DONT ****ING MAKE THAT DIRTY EITHER) Thanks...
Old Jan 19, 2006 | 09:43 PM
Tahoe SC's Avatar
no mang...it's like this...you had a perfect fit but over time, the parts wear and now there are gaps where there used to be 'parts'...
lubricant won't do much as you will still feel the play.
T
Old Jan 19, 2006 | 10:08 PM
eteller's Avatar
I'm trying to bed in new EBC HH pads which I've had for over 300 mi. now, and one rotor only shows only partial contact with the pads, so I'm braking kind of harded than normal to get them to wear to fit. The noise only occurs then (semi hard braking). I screwed around with the clip ons moving them up, so I thought that might be it, but their tight and loctited on. No noise turning side to side.
Old Jan 19, 2006 | 10:47 PM
Tahoe SC's Avatar
check the last thing you did before the problem began...should be it! but check them head bearings too
F4iFern
Jun 4, 2011 04:54 PM
Terrj
Aug 18, 2010 10:21 AM
bajaroots
Jun 11, 2009 04:35 PM
lamby
Dec 15, 2007 03:43 PM
