Steering alignment
Old Aug 12, 2005 | 11:05 PM
Gdub's Avatar
Default Steering alignment
Hey, unfortunately i recently went down. [:@] In the end I hit a curbing at ~5-10 mph and the front steering is tweaked. Is it easy to realign the wheel with the bars or do I need to take it in to a shop? Any other things I should be cautious of? I've never had to do much work on the bike before. Thanks!
Old Aug 13, 2005 | 01:02 AM
sirlimpzalot's Avatar
Default RE: Steering alignment
depending on the severity of the impact, it is possible the forks are "twisted" in the triple clamps..try loosing the lower triple tree mounts..NOT THE TOP ONES UNLESS YOU WANT YOUR BIKE TO SLAM T OTHE GROUND!!
with the bottom clamp loose, see if you can put the front wheel between your knees and straighten it out that way. You may want a "spotter" to help hold the bike..if it straightens out, the make sure to RETIGHTEN the lower clamps
Poblete
Jul 6, 2011 05:15 AM
CeeBeeAre600
Jan 14, 2010 04:42 PM
johnnyx
May 29, 2009 06:39 AM
BK600
Oct 9, 2007 10:59 AM
jacobsdr
Apr 13, 2007 01:24 AM
