starting problem help !
RE: starting problem help !
xuracing u sure is dats it b/c it started and worked well,but den my cuzin got on i was trying to teach him how to get out for first gear and he stalled out then when i go to start it again that problem happen i dont want to take it to a shop yet i wanna hear from the forums first cuz u guys kno bikes very well
Things I would check (In this order).
Bank Angle Sensor - Reset
Fuses - Check (don't believe the bike will allow itself to start itself with a blown fan fuse)
Fuses - Try starting without the headlight fuse (seperate wiring harness problem. easy fix)
ECU - Dielectric grease/clean
Kickstand Switch (dielectric grease)
weird jolts like that will cause corroded connection pins to get disconnected. it's happened to me many times. buy some grease and lube up.
