Spray paint the inside or the outside of the windscreen?
Old Aug 4, 2008 | 06:16 PM
sonyab523's Avatar
Default Spray paint the inside or the outside of the windscreen?
I know a few people have does this as oppose to buying a new one. So just wondering if you sprayed the outside or the inside. I have Krylon Fusion, will that work?
Old Aug 4, 2008 | 06:41 PM
TheX's Avatar
Default RE: Spray paint the inside or the outside of the windscreen?
inside, fusion is great paint for most plastic.
Old Aug 4, 2008 | 07:13 PM
maximus3's Avatar
Yep inside Ive done it on my other F4i. it came out good.
Old Aug 4, 2008 | 07:30 PM
Xuracing's Avatar
the previous owner did it on both .. i don't recommend it but it depends on what you are going for
Old Aug 4, 2008 | 08:19 PM
sonyab523's Avatar
Better stick with the inside, I cannot get one of the screws off the windshield to save my life. I went to the store and bought WD-40 and still nothing. Its pissing me off. Any other ideas?
Old Aug 4, 2008 | 08:30 PM
Jamesbonz's Avatar
It would look TERRIBLE on the outside. I sprayed the inside of the screen on my F4 turned out fairly well, just a temp fix until I get a ZG.
Don't even attempt to spray the underside if you can't get the screen off, I'm sure that would cause more problems than worth it.
Old Aug 4, 2008 | 08:39 PM
Scoobyrunner's Avatar
Why not just buy a windscreen off of ebay for the $20 that some of them are? I bought one and the fitment is perfect, I also bought a set of windscreen bolts that worked perfectly ended up only spending maybe $35 all together.
Old Aug 4, 2008 | 08:44 PM
sonyab523's Avatar
ORIGINAL: Scoobyrunner
I was doing that and I ended up fogetting to bid and had to rush with 5 seconds left, ended up not getting it and I got upset, so I figured I'd go spray paint it. But I won't be doing anything if I can't get this screw off [:@][:@]
Old Aug 5, 2008 | 02:21 AM
Aken's Avatar
July 2008 ROTM
The $20 windscreens will likely not fit anywhere near as well as the OEM or a more expensive brand. Painting the windscreen is an easy and cheap DIY upgrade.
Old Aug 5, 2008 | 06:26 AM
snakevenom1's Avatar
I agree I painted mine and now all my buddies are painting thiers.
