SpeedoHealer/SpeedoDRD for -1+2 gearing
Old May 26, 2011 | 07:03 PM
blackN_yellowf4i's Avatar
Default SpeedoHealer/SpeedoDRD for -1+2 gearing
I bought an f4i with -1+2 gearing and the speedo is way off. I'm about to order a speedoDRD but was wondering how hard it is to install and calibrate for a noob??
Also one problem is that the previous owner didn't install a speedohealer so it added A LOT of non-existent mileage to the bike. Is there any way I can program the speedoDRD to under run the mileage? Like for every 100mi I ride.. it only adds 50mi to the mileage?
Old May 26, 2011 | 07:36 PM
F34Me?'s Avatar
The DRD is very easy to install and calibrate. If you have problems just get a mechanically inclined friend to help. You can send your gauges away to get the milage fixed. I think it costs about $75 to do so.
Old May 26, 2011 | 10:15 PM
xtremef4i's Avatar
I too have the DRD. it is very easy to program.... easier to program than the Speedohealer I had and cheaper.... if you want your speedo to be acurate, ther is no way to make the bike read less miles....
Old May 27, 2011 | 03:35 AM
LasVegasHarley's Avatar
I have a speedoDRD as well. It's easy to install and program. I have -1/+1 sprockets. With Bridgestone BT 016 tires, my speedometer is GPS confirmed accurate with a setting of -13.2
Old Jul 29, 2011 | 10:23 AM
mbison83's Avatar
I got the SpeedoDRD and the RK Quick Acceleration chain and sprocket kit that I will be installing on my f4i today. Can anyone walk me through the correct programming of the SpeedoDRD for that setup?
Old Jul 29, 2011 | 07:59 PM
xtremef4i's Avatar
If you cant figure out the directions provided in the instruction booklet, just give the owner Brooks a call. he will tell you how to do it and walk you thru it. I found the directions to be confusing but I called him and I had it programmed in about 30 seconds
Old Jul 29, 2011 | 11:19 PM
mbison83's Avatar
Well, I was thinking that you guys would know how to program it with the 15/46/520 setup.
Old Jul 29, 2011 | 11:32 PM
ucyifly's Avatar
That would be 11.2%. Go here for links to the calculator (which I used to get your correction amount), a video of how to setup the device, and the manual.
Old Jul 29, 2011 | 11:47 PM
mbison83's Avatar
After inputting the 16 to 15 (front sprocket) and 46 on the rear, with 120/70/17 tires I got -6.2%. How did you get 11.2%?
Old Jul 30, 2011 | 12:12 AM
ucyifly's Avatar
First of all, you use the rear tire size, not the front, which is 180/55/17 if you are still running the factory size.
As for how I got 11.2%. It's 6.2% off due to the gearing change, then another 5% for the factory speedometer error. See, I have always heard that motorcycle speedometers were inaccurate from the factory, that calculator claims most sport bikes are off 5%. Go back and look again with a little closer attention to what you are reading and you will see it.
