Speedohealer
No it's not hard. Just do it, and take your time. For mine, the hardest part was getting at the three-wire plug, which happened to be under the coolant overflow tank, which involved removing the top bolts of the sub frame to get under it. Not difficult by any means, just took longer.
How many hours should I allow? I don't want to run out of sun light
It's really not hard, you just need to take some stuff off so you can have easier access to the plug. Not any worse than changing your air filter or similar.
Edit: Then again, I had my bike apart anyway for other upgrades, so it wasn't a big deal. Installing JUST the Speedohealer will be time consuming for a seemingly simple mod.
