Speedo problem
Old Nov 24, 2008 | 01:13 AM
adidas00's Avatar
Default Speedo problem
I faced recently with an anoying problem! When i ride my bike, sometimes the speedometer does't work, it shows 0 km/h and the FI light is on (only sometimes). I turn off the engine, start back and then it's ok...for a while. I've noticed that, the problem with the speedo appears mostly when I shift from 1st to 2nd gear. First I put the blame on weather, because I live in Romania and it's winter here already, +2 degrees Celsius.
Anyone had this problem?
Old Nov 24, 2008 | 01:24 AM
Stephens's Avatar
Default RE: Speedo problem
I haven't had that exact problem, but I think I have an answer to your problem. When the F1 light comes on, its a code saying theres something wrong with your bike. If it is happening intermitterly and not all the time, it sounds like your speedometer wire has come loose and just needs to be secured.
Here is a link of where it is located
http://www.speedohealer.com/your_pic...i/tutorial.htm
This is the tuturial of installing a speedohealer, but shows you where to look for the wire. Good luck.
Old Nov 27, 2008 | 01:16 AM
adidas00's Avatar
Thx Steph
Old Nov 27, 2008 | 07:23 PM
jaynd's Avatar
sounds like it could be your speedometer sensor. i had similar problems around 18k miles. my speedo would stay at zero, mileage wouldnt budge. asked around on here and found it was the speedosensor. might want to look at that as a posibility too, chief. i hope you get'er fixed!
Old Nov 28, 2008 | 08:45 AM
kukku's Avatar
+1. Mine went bad as well and had to have it replaced. If IIRC it's error code 11 (FI light flashes) but stand to be corrected.
Old Nov 28, 2008 | 03:49 PM
BigNate354's Avatar
yea bro its ur speedo sensor mine went bad about 2 months ago, i was able to replace it myself but to do so u have to take off the tank, off the air box, take off the throttlebody, remove all the coolant lines and fuel lines that are linked together ontop of ur trani to get to the speed sensor, its located right on top of ur trani and its two bolts and a wireharness, if ur not mechanicaly inclined do not do this urself, if you are refer to ur service manual and if u dont have one download one at cbrextreme.com.... it shows ur exactly what to do, but get a couple quarts of coolant and make sure ur tank is pretty much empty or its a pain in the ***..... good luck to ya
Old Nov 28, 2008 | 03:50 PM
BigNate354's Avatar
oh yea and u can find the sensor online for about 75 bucks... its not expensive at all
hillbilly86
Jun 29, 2013 09:17 PM
cjones120201
Nov 17, 2012 12:34 PM
krulewicz18
Jan 18, 2009 02:53 PM
sportracer07
Feb 26, 2008 09:05 PM
n_vanexel31
May 11, 2007 09:52 PM
