Spark plugs?
Old 09-22-2012, 09:28 AM
vegas_rebel's Avatar
FPR isn't a bad swap; just a couple of bolts and you don't even have to take much else off.
If you're mechanically inclined enough to do the brakes, you can do the FPR no problem.
Old 09-22-2012, 07:18 PM
lstat's Avatar
Sounds easy enough, I may have to tackle that if it is the problem. Cross your fingers for my sake!
Old 09-22-2012, 07:25 PM
74demon's Avatar
Just remember to take out the shipping plug on the new part before install.
Old 09-23-2012, 10:55 PM
mnguyen84's Avatar
hahaha. the ecu could be the problem? technically that isnt a lie, but it also sounds like a load of crap, because it's too early to tell. As mentioned above, start with new plugs and pads, before you start suspecting the ecu. You might also want to invest in a compression testing kit. Harbor Freights has a cheap one that's pretty good. You just need a 10mm adapter.
baseballkid
10-04-2012 07:48 AM
jvhjgh2006
06-26-2011 02:07 AM
Carbon_cavvy
02-29-2008 08:25 PM
eukanuba517
02-19-2008 04:54 PM
mikey1297
07-11-2006 02:42 PM
Quick Reply: Spark plugs?
