Side mirror coming loose
Old Apr 23, 2009 | 03:11 PM
thef4i's Avatar
Default Side mirror coming loose
Hey guys my mirrors keep coming loose. Even if i tighten it really tightly, after about 5 minutes of freeway riding, it starts to fold and the screws get loose. Any suggestions? thanks
Old Apr 23, 2009 | 03:34 PM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
If you mean that it's folding at the ball pivot, then it's time for a new mirror, imo. Look in e-Bay (cheap). As for the bolts coming loose, you can go with a thin lockwasher. You may also want to make sure you have the correct bolt size. It sounds to me like they're not.
Old Apr 23, 2009 | 03:37 PM
terror rising's Avatar
There's always Loc-tite!
Old Apr 23, 2009 | 05:35 PM
thef4i's Avatar
By ball pivot, do you mean where the screws connect with the mirror? Cause thats where the bolts are coming loose. I'm sure the bolt size is correct because this is the first time this is happening.
What's a Loc-tite?
Old Apr 23, 2009 | 05:45 PM
Incognito's Avatar
Talking
LINK
Just put a little drop on the threads & it'll keep them from backing out. Only use the "blue" (medium strength) stuff.
Old Apr 23, 2009 | 05:58 PM
thef4i's Avatar
Wow! That was fast.
How much is loctite? And what is a thread? Thanks
Old Apr 23, 2009 | 06:11 PM
Incognito's Avatar
Talking
The spiral thingies on the outside of the bolt/inside the nut(s).
Old Apr 23, 2009 | 06:26 PM
thef4i's Avatar
hahaha. ohhhh. thanks
Old May 28, 2009 | 03:51 PM
thef4i's Avatar
Default Update
The loctite threadlocker worked really well. I bought the red one though. I might have a hard time taking the bolts off later but I haven't had a problem with the bolts coming loose since.
Old May 28, 2009 | 04:07 PM
MANMADE's Avatar
You got red?
Well don't worry about taking them off, unless you have a torch and are ok with melting plastic
