Share PCIII MAPs??
Old Sep 28, 2012 | 11:57 PM
JHillCBR's Avatar
Registered Users
Default Share PCIII MAPs??
If your willing to share your PCIII MAPs, Post em UP!
Heres a MAP someone shared with me. Not sure where they got it from but it seems to run preety well with it. Also using the Accel Pump RACE Settings - 75% Sen. 20% Fuel. 15 Engine Revolutions
Try it out if you like. Maybe we can work togeather and make it better?
Seems to pull preety nice along with the Accel Pump Enabled but as always theres still room for improvement...
File Type: zip
01 F4i MAP.zip (965 Bytes, 24 views)
Old Oct 1, 2012 | 08:16 PM
C Jacob W's Avatar
What pipe and filter you running?
Old Oct 2, 2012 | 01:27 PM
JHillCBR's Avatar
Registered Users
I Just have a DanMoto pipe and stock air filter.
Old Oct 2, 2012 | 01:33 PM
C Jacob W's Avatar
Im just running the yoshi rs3 map with stock filter. I just got it on so im gonna run with this for a bit then ill try that one out. Im running 85% sensitivity 20% fuel 15 revs
Old Oct 2, 2012 | 02:06 PM
JHillCBR's Avatar
Registered Users
Right on let me know what you think of the map I uploaded. Im still playing around with my accel pump settings to find what works best. Really theres not much of a diffrence when using it, But theres enough to tell.
Old Oct 2, 2012 | 08:20 PM
C Jacob W's Avatar
ill try it out later. Ive had the power commander on for only a couple days. I havent noticed much of a difference with it yet though
Old Oct 2, 2012 | 09:24 PM
boredandstroked's Avatar
A base map is a good start but your not going to make it any better without a dyno providing real feedback. Dyno time is relatively cheap to make a couple pulls and get a perfect map for your setup. That and everyones bike is different, even with the same parts. What works for you might not work for others.
Old Oct 3, 2012 | 01:39 AM
JHillCBR's Avatar
Registered Users
Right on. I been meaning to get the bike on a Dyno and just having a custom map done, Its just the funds stoping me from doing so at the moment. But will hopefully be doing so soon.
Old Oct 3, 2012 | 08:01 PM
C Jacob W's Avatar
Yeah its expensive around here. Like around $300
Old Oct 9, 2012 | 09:01 AM
vr6ptstyly's Avatar
Any one have a good map for a M4 High mount? Think Im running the Jardine high-mount file. TIA
