rr tail on f4i
Old May 2, 2010 | 05:46 PM
2002 f4i 600's Avatar
Default rr tail on f4i
ok i'm new to the forum. i've read alot of conversions about putting a rr tail with undertail exhaust. but i just want to install the tail section , is it possable. i have an 2002 f4i, i only want to know because mine is cracked. and i like the vents on an rr, if not i'll buy a new tail.
Old May 2, 2010 | 06:40 PM
Stephens's Avatar
You can but you have to get a new tail end subframe to install it. And then are you going to change your exhaust to go under the tail or out the side?
vangill's Avatar
July 2010 ROTM
its possible, but you have to mod it to make it work, for bolt on application-just do the f4i tail, if youre feeling like fabricating, try the rr tail
Old May 2, 2010 | 06:51 PM
cool thanks for the input i could fab but, i think i'll stick with the stock look. cause i'm sticking with my exhaust it's off a r1, it looks good on the side. so thanks again.
Old May 2, 2010 | 10:28 PM
HrGomez's Avatar
Default Stephens..
i want the exhaust under,,,!
what i need?
02 600 f4i
Old May 2, 2010 | 10:34 PM
vangill's Avatar
July 2010 ROTM
a lot of fab work, it wont be a bolt on deal, but basically any idea you can get it under there would work, just consider the heat factor under the seat
Old May 3, 2010 | 03:20 AM
Zero1080's Avatar
I'm going to lock this thread because this has been asked before, and there are write ups AND pictures. Plus every question you could have answered.
what i need?
02 600 f4i
Plus, when you post things like that. It makes me want to punch a child.
Old May 3, 2010 | 08:35 AM
Shadow's Avatar
This has relevance
Oh let me not forget to said, my English is not good, and that i'm original from DOMINICAN REPUBLIC
https://cbrforum.com/forum/new-member-area-5/hi-every1-one-more-massachusetts-109809/
cds83
Jul 3, 2013 12:05 AM
