which reversed forks will fit my 01 cbr f4i?
Old Nov 4, 2013 | 09:07 PM
BitRex's Avatar
Default which reversed forks will fit my 01 cbr f4i?
So i feel and bend my forks now i need a new set or forks. i did some research and people saying reversed forks are better, I thought since im getting new once why not get the reverse ones. my Question is have anybody changed their's? if so which ones will or can fit my 2001 honda cbr F4i.
THANK YOU. lol
Old Nov 5, 2013 | 05:46 AM
"A"'s Avatar
"A"
USD fork conversion requires replacement of triple clam, front wheel, most likely brake calipers and clip-ons. Basically complete frond end, find something that's compatible shouldn't be hard, just check the steering stops for the lower triple clamp to allow proper steering clearance.
Fork trail can affect steering and braking attributes, depending on what type of steering/braking performance you ultimately want to achieve, select the front end you want to convert.
Old Nov 5, 2013 | 05:50 PM
dylanhunter's Avatar
i have 2004 cbr 1000 forks on my 2001 f4i. feels great and fits perfect
Old Nov 7, 2013 | 12:46 AM
YunMing's Avatar
If you can get a set of stock forks and drop in better springs along with a fork brace you should be good
Old Nov 7, 2013 | 01:29 PM
"A"'s Avatar
"A"
USD forklegs may look nice as a conversion, but without proper springs/valving setups that suits your riding in particular, the USD forklegs will just give you frame additional stress in comparison to OEM forks.
Properly setup OEM forks can perform just as well as USD forks, whether a person can "feel" the difference or benefit of USD fork conversion is highly doubtful.
But if your OEM forklegs are toast and your front wheel has a dent that needs replacement, converting your frond end to USD forks may just be worthwhile, just make sure you get the springs/valving to match your bike properly.
Old Nov 7, 2013 | 07:52 PM
omg209's Avatar
does it really? i mean an exact fit with rims and everything?
Ls1Mx5
Mar 4, 2015 08:03 AM
Cone_eater
Dec 16, 2010 06:09 AM
brancart1
Nov 15, 2007 10:10 PM
cbr_newbie
Sep 18, 2006 03:38 PM
brancart1
Oct 19, 2005 05:16 PM
