Requesting pictures of wires
Old Mar 14, 2012 | 07:44 PM
nrmskate's Avatar
Default Requesting pictures of wires
If someone could, It would help me out sooooooo much!
I need pictures of the wiring going from the brake switch, front brake switch, and the coolant temperature sensor.
Also a picture of the radiator fan plug wiring would be much appreciated.
Thank you!
Old Mar 14, 2012 | 08:33 PM
nrmskate's Avatar
Or if someone would like to label these, I would appreciate it!
Old Mar 14, 2012 | 10:23 PM
F4I_Bob's Avatar
3) Computer
4) Coils
5) Regulator
7) Fuse box
9) Upper SUB HARNESS(see pic attached) Green is ground on honda.
10, 11, 13, 14) Relays (fuel pump relay is one of them)
Showing a pic up the upper subharness (i have a extra one with relays on it)
Also with the RAD, i have it bypassed so its ALWAYS on when i turn the bike on.
Hope this helps out bro, any questions feel free, if no one eles posted pics, when i paint the bike next week ill get you pics out the *** when everythings off the bike.
Old Mar 15, 2012 | 12:34 AM
nrmskate's Avatar
Thanks a bunch for that. I also have my fan bypassed. Do you have a picture of the wires running from the rear brake switch to wherever? Thanks again!
Old Mar 15, 2012 | 12:57 AM
F4I_Bob's Avatar
Ill try to grab that pic tomorrow, i knew i was missing something lol. but they run up and plug in under the rear of the tank. ill see what pics i can get in the morning/ afternoon.
Just as a FYI, that isnt a f4i wire diagram which is where you maybe running into some issues.
the f4i has several sub harness that come off the main wire harness. One sub for the front, One sub for the rear (taillights, tag light, signals ect), sub harnesss for the throttle bodies, Sub harness for the stick coils. that diagram looks like its for the cbr f4 maybe. but most defentally not the f4i
Old Mar 15, 2012 | 12:08 PM
nrmskate's Avatar
I'll take note of that and try and get the right picture, in the meantime, can you take a picture of how the rear brake switch is held and where the wires run to? Thanks a bunch!
Old Mar 15, 2012 | 09:01 PM
nrmskate's Avatar
Also can you take a picture of the sensor on the radiator, mine just simply doesn't have a wire going to it.
Old Mar 15, 2012 | 10:46 PM
F4I_Bob's Avatar
Everything is covered by plastics atm. sorry bro. gonna have to give me a few days.
Old Mar 15, 2012 | 10:55 PM
nrmskate's Avatar
Alrighty man, appreciate it. What about the wires coming from the left handle controls? Can you get me a picture of where those go? I'm just referring to the two sets of t wires only. One long and one short. Thanks!
Old Mar 15, 2012 | 11:59 PM
F4I_Bob's Avatar
Should have 3 sets of wires coming out of the left controle (clutch side),
short set with 2 females, they connect to the stock clutch perch. (as pic shows, i do not use a stock perch, but have the stick one still)
long set with 2 females, they connect to the horn
then the last set has one or 2 square plastic connectors which plug into the main harness.
(fyi, if your bike turns over but doesnt start its due to the bike not having a bank sencer. you can use a peice of wire to jump that, or buy the upper subharness with the sencer attached)
Sorry its crappy pic, but wires im holding are horn, other wires attached to perch are the ones your talking about.
