Replacing CCTL - need top off engine?
Old Jul 18, 2008 | 05:23 AM
spikeywan's Avatar
Default Replacing CCTL - need top off engine?
Hi Guys,
I've read everything I can find about replacing the cam Chain tensioner Lifter (or just CCT to some). I also have a Honda workshop manual, and a haynes manual. My bike's a CBR600F2 2002 model.
In the haynes manual, it says to take the cam cover off, and the timing cover off, find top dead Center, THEN replace the CCTL.
In the Honda workshop manual, it has a section on removing the camshafts, and in this it tells you to take the cam cover off, and the timing cover off, find top dead Center, THEN remove the CCTL, etc, etc.
BUT, in a later section titled Cam Chain tensioner Lifter, in the Removal section, there's no mention of finding TDC, or removing the cam cover.
Could the Haynes manual havecopied and pasted the wrong section?
So I'm confused. A honda mechanic told me that I must find TDC, and be really careful to ensure that the cam chain doesn't jump teeth, and check the timing afterwards carefully, yet I've heard many people talk of simply removing and replacing teh CCTL without opening the engine up.
Is there anyone who knows for definite whether I need to find TDC to do the job?
Thanks.
Old Jul 18, 2008 | 08:47 AM
ExVictory88's Avatar
Default RE: Replacing CCTL - need top off engine?
no just dont move your bike at all while your doing it there would be no need to as long as it doesnt move brah! i took mine out and put it in with no problem GL
Old Jul 18, 2008 | 09:31 AM
Tahoe SC's Avatar
not saying that your bike will get fubard without doing it...cause it might...
but i don't know of anyone who set it to TDC. just removed and replaced.
i've done it 3x on my bike...each time just took out and put back in.
Old Jul 18, 2008 | 09:35 AM
WOT's Avatar
WOT
You said you have a CBR600F2 2002, but I am guessing you meant F4 right?
Here is everything you need to know!
http://www.bossturbo.com/cbr/howto_cct.shtml
http://cbrworld.net/forums/thread/85183.aspx
Old Jul 18, 2008 | 09:54 AM
DBEAU's Avatar
No finding TDC here. just a remove and replace, works great.
Old Jul 18, 2008 | 09:56 AM
spikeywan's Avatar
Thanks guys.
The 2000 model was an F4i, then from 2001, they restarted the F1, F2, F3 and the FS1, FS2, etc.
But yes, it's the same as an F4i
At least that's how they go in the UK.
Old Jul 18, 2008 | 06:24 PM
WOT's Avatar
WOT
I am actually just about to put in a new stock one myself and I just noticed in the manual that it says to turn the tensioner shaft fully in and secure it using the stopper tool to prevent damaging the cam chain. What do you guys think about that? I don't have this tool.
Old Jul 18, 2008 | 08:34 PM
DBEAU's Avatar
When you buy the new CCTL the stopper tool should come with it.
Old Jul 18, 2008 | 09:03 PM
WOT's Avatar
WOT
Mine does have the piece of flat metal like in those writeup, but the manual shows something much larger like a key.
Old Jul 19, 2008 | 02:43 AM
DBEAU's Avatar
the "key" you're referring to may be neccessary to retract the shaft back into the body of the lifter. On mine i accidentally pulled out the stopper tool and the shaft shot out. I just took a small flat head screw driver and stuck it down there and turned it which pulls the shaft back up, then you just hold the shaft with your finger and put the stopper piece back in.. So... if what you are talking about is the tool to retract the shaft, then a small screw driver will do, although you shouldn't even need it.
Hope this helps.
