Rear shock linkage bolt torque
Old Jun 16, 2016 | 06:01 PM
gcon45's Avatar
Default Rear shock linkage bolt torque
Hi guys.
I have to replace the lower bolt on the rear shock linkage as the threads are stripped on it.
The nut on it is self locking so I assume the torque setting won't be that high.
Many thanks!
Old Jun 17, 2016 | 07:09 AM
gcon45's Avatar
Just to note - it's number 12 in the illustration.
Old Jun 18, 2016 | 08:14 AM
gcon45's Avatar
Sorry - moderators - could you move this thread to the F4i section?
Old Jun 19, 2016 | 06:48 AM
Conrice's Avatar
Its in the main F4i section. Hopefully someone comes along with info from the manual. Those bolts and nuts are usually really tight. They're the only thing holding the rear of your bike up, that's why they're self locking. The bushing and bearing keep the link from binding
Old Jun 19, 2016 | 10:55 AM
33 foot pounds or 44 newton meters
Old Jun 19, 2016 | 01:07 PM
rfesu's Avatar
everything holding the rear shock and its linkage on is also 33 ft-lbs.
since you're hanging the rear of the bike to do the job, it's a good time to service that assembly while you're there; i recommend disassembling the entire rear shock link and lower so you can clean and re-grease all of the needle bearings, and re-torque everything. it'll only take a few extra minutes.
edit: if you pm me i'd be happy to email you the entire rear end service manual section...
Old Jun 29, 2016 | 11:20 AM
Ditch's Avatar
What kind of grease do you recommend?
Old Jun 29, 2016 | 12:08 PM
rfesu's Avatar
it's just a low speed needle bearing; any thick grease will do...
HenryM
Feb 22, 2014 03:28 PM
98CBR600F3
Mar 13, 2007 12:57 PM
