Rear Sag Question?
Old Aug 3, 2010 | 10:33 PM
motox77's Avatar
Default Rear Sag Question?
So I decided to try can set my sag because me being a bigger guy (225) I knew it needed to be stiffer. I went out and got the spanner and tried to adjust it only to find out it seemed to move only one click.
My question is am I to heavy for the what I think is the stock spring even though the book says it can carry up to 300+ pounds. Do I need to try and find a stiffer spring? Or am adjusting it some how wrong? I couldn't really tell where the mark is that lines up to the number on the collar..
Any advice is welcome, besides the obvious of me losing weight.. I'm working on that :-P
Thanks!
Old Aug 4, 2010 | 08:33 AM
some guy #2's Avatar
Turn the preload all the way to the max (which it might be already). I think the rear shock is a ramp collar so it can only turn so much.
BTW, the stock stuff will not let you get a good sag number. Set the preload to max and then put the comp. reb in the middle and go from there. There isn't a lot you can do or even adjust with the stock stuff however.
Old Aug 4, 2010 | 11:16 AM
LoneWolf04's Avatar
if youre having a hard time turning the the collar try shooting it with some lube. Mine froze up on me and i went to put it up to ride a passenger and coulnt get it up all the way.
Old Aug 4, 2010 | 12:17 PM
DBEAU's Avatar
Use an extension. The rear preload adjuster is a real bitch to turn. There are 7 settings. and If you pull hard enough, 7 will snap back down to 1.
Old Aug 4, 2010 | 12:49 PM
boredandstroked's Avatar
The spring is not ideal for your weight but you can make it work fine for street and canyon riding. I've ridden 2up [around 270lbs combined] canyon runs at blistering speeds to the point of breaking both peg feelers off so the suspension can be made to work.
Old Aug 5, 2010 | 12:14 PM
MitchA's Avatar
Good video here: http://sportbikewrench.com/howtovideos.aspx
cbrF4n
Nov 24, 2013 04:28 PM
TorreyG123
Oct 5, 2013 11:24 PM
akubat
F2 Tech
Jul 27, 2012 08:36 AM
buddah
Jul 21, 2008 09:12 AM
Lrn2Go
Aug 8, 2007 11:07 AM
