quick qeird question
Old Aug 30, 2006 | 09:31 PM
FastCRX's Avatar
Default quick qeird question
i just noticed on my recipt for my exhaust order i picked the Cali model exhaust. I know those guys got smog restrrictions out the wazoo so should i correct the order? Or is it just a stamp?
Old Aug 30, 2006 | 09:58 PM
BMoneyF4i's Avatar
Default RE: quick qeird question
i think it just means you have a place to plug in a o2 sensor it looks like you got a 06 so your bike is built to ca emmisions standards anyway i believe atleast thats what i was told which once again just what i was told means not only that you have an o2 sensor but a less aggresive cam i could be wrong here tho
Old Aug 30, 2006 | 10:00 PM
lifties's Avatar
It means your new mid-pipe will have a bung for an O2 sensor. You could send it back, or possibly correct the order before it ships. If not, then get a bolt to plug the bung with. Do a search for "O2 sensor" and there is a thread that tells exactly what size bolt to get. I would use high temp sealant on the bolt threads. Your new mid-pipe might ship with a bolt in the bung.
This is the only difference between a CA model and a NON-CA model.
Old Aug 30, 2006 | 11:51 PM
dwhite645's Avatar
You'll need the CA model exhaust since yours has an 02 sensor. Let the order as it is.
Old Aug 31, 2006 | 12:22 AM
jimd2p's Avatar
When I ordered my Yosh pipe, I ran in to a similar thing. All 06 F4is have an O2 sensor (as far as I know). The exhaust I ordered was a non CA model. If that is the case, all you need to do is order an 02 sensor eliminator. Dynojet has them for around $20.00.
If you end up with an exhaust with an O2 hole and you don't run a sensor stock, just plug it.
Old Aug 31, 2006 | 12:47 AM
FastCRX's Avatar
sweet thanks fellas
Old Aug 31, 2006 | 01:15 AM
Fly5150's Avatar
Man, a bolt in your bung? Depending on the size of the bolt, that might hurt a little bit...[sm=alcoholic.gif][sm=badidea.gif]
ORIGINAL: lifties
CBR_GreenMonster
Aug 13, 2009 08:00 AM
viva_brasil
Jun 9, 2008 04:38 AM
rke2121
Feb 6, 2008 05:45 PM
bboi
Jul 9, 2007 10:08 PM
cassimero
Aug 3, 2006 10:33 AM
