Pretty Sure I'm Close to overheating
Read through some of the older posts about running temps, and idling temperatures in the city.
On a hot day I've noticed riding in the city temps are around 113-115 then can get up close to 117 even hitting briefly 120.
I am thinking bad thermostat? And a coolant flush/change is needed?
If this doesn't solve it, probably going for a fan switch mod, but that would only mask the issue.
Anyones input on the temps being high and the thermostat and fluid change idea would be great.
Thanks.
Thanks.
Thats too hot. The manual says the temp light and FI lights will come on at 250F and then you need to turn the bike off. Thermostats fail open... it would take longer to warm up, but wouldn't effect overheating. So your fan is working? I would definitely change and flush the coolant.
Okay thanks, sounds like it isn't a failed thermostat.
Yes the fan is coming on, I can hear it and see the temp drop.
I watched it today riding to work this morning. On the highway driving sits about 84 C. In the city driving about 94-95 C.
Sitting stopped in traffic it got up to 115 C and the fan was on.
I'll try flushing the coolant and doing a change friday.
