powdercoating rims + lowering
Old 03-11-2008, 07:46 PM
dilysi1985's Avatar
Default powdercoating rims + lowering
just wanted some advice and tips on changing the color of my rims and also lowering my bike. Maybe there is someone out there in FL that could suggest where to get this done. Im in Port Saint Lucie.
Thanks
Brandon
Old 03-11-2008, 08:59 PM
bwayers's Avatar
Default RE: powdercoating rims + lowering
best tip for lowering - don't
Old 03-11-2008, 09:52 PM
+1
Old 03-11-2008, 10:39 PM
Just remember on the powder coating.... You have to remove the bearings! If you punch them out make sure you replace all bearings and seals! I just did mine orange Came out real nice!!! Makes sure who ever you have do the poweder coating, that they plug the wholes where the screws that hold the break rotor(s).
Old 03-12-2008, 09:33 AM
you could also just strip the black and keep them as a polished aluminum. I did just the outer lip on mine and it looks great. I polish them once every two weeks when i rid with just a drill bit polishing tool. It only costs about 10 bucks to do it but it does take a little time and patience. i think itlooks better than doing a powder coat. just my .02
Old 03-12-2008, 10:02 AM
patman's Avatar
why not lower a bike? also got pics of the stripped rims?
Old 03-12-2008, 10:58 AM
ORIGINAL: F4itanner
what do u mean u can strip the rims. you just sand the black off and its aluminum under the black paint????????????
Old 03-12-2008, 11:02 AM
My brother in law lowered his Ninja and all the balancing changed,especially cornering. We raised it right back up after 1 week. He said it was scary to ride. Not to mention he would bottom out on speed bumps, doing wheelies. In other words he hated it.[:@]
Old 03-12-2008, 12:45 PM
bluej511's Avatar
Unless your doing a lot of turning which i hear in FL there isn't. Id lower the bike front and rear. I raised mine back up because i plan on doing twisties once i get better. Lowering is bad for handling/cornering. but if you dont do much of that then go for it. f4i doesnt look bad lowered
Old 03-12-2008, 01:04 PM
i wouldnt polish the Whole rim. its a bitch to keep clean. but im sure the lip would be easier and look nice.
+1 w/ bluej
Quick Reply: powdercoating rims + lowering
