Poor man's 2001 600 F4i project
Whats up all,
Just picked up an 01 f4i on Friday thinking it would need x amount of work but as it turns out in needs y...this thing has been neglected pretty bad so who knows when I'll find the end of the tunnel. Fortunately its a Honda and with a little tlc I'll have a fire breathing steed in no time. Im also mechanically inclined with a decent dirt history so I'll be doing all the work myself.
Needs normal wear items: chain, sprockets, brakes, rotors, suspension seals and service, engine service, valve adjustment, tires, signals, fluid flush, levers, grips, ends. Every piece of plastic on this unit is cracked so a little loctite plastic epoxy and sheet metal and I'm on my way.
The swingarm and subframe have a small amount of corrosion due to what I believe was a leaky battery prior to the one installed...removed subframe, stripped and rattle can paint should do the trick...
Went ahead and checked the valves...out of spec. Looking for shims now.
Tons of parts ($1000 or so) on the way . Hoping to have her road worthy in the next 4-6 weeks.
If the intake clearance is supposed to be .20 mm +/- .03 mm, and I cant get a .15 in there (my gauges are in increments of .05 mm) that means my intakes are potentially .03 mm out of spec at LEAST, which contradicts everyone elses "ive got 60k on mine and only one valve was out". Im also using flat gauges which are pretty tricky to get a good measurement considering the drag on the cylinder head itself.
Before I go all tazmanian devil on this fine piece of Japanese precision, im gonna make some bike specific feelers and re check...
On a side note, subframe has dried and been reinstalled. Will be slapping the rear cowl and fender on tomorrow pm and securing the wiring. Then we wait for UPS.
20500 mileage...which after a bit of research concerns me a tad...
-Poss
Upon a little "persuasion" ALL of my exhaust valves are within spec...
All the intakes but 1 are out...
Adjusting them now.
