plzzzzz help me
Old Jun 22, 2010 | 09:32 PM
pollock009's Avatar
Default plzzzzz help me
ok i have a 2001 cbr f4i got done ridein one day went back out to take off didnt happen heres the problem no front turn signals no headlights no fuel pump anyone know wats up ??? plz help
Old Jun 22, 2010 | 09:37 PM
Krux's Avatar
Did you check fuses? Are the lights lighting up on the gauge cluster? Can you hear fuel pump noise when turning the key. Need more info
Old Jun 22, 2010 | 09:52 PM
pollock009's Avatar
all fuses are good everything works but the headlights an front turnsignals an the fuel pump regulater tests good i have no idea lol
Old Jun 22, 2010 | 10:00 PM
tanrush's Avatar
My best guess is your battery shorted and is fried. If I am reading your post correctly. You rode the bike, everything was fine. When to ride again and no lights, turn signals. Is that correct.
I did the same thing a couple weeks ago. I rode everything was fine. Next day I turned the key and everything lite up on the dash. I hit the started button and everything quit. I thought it was a fuse but everything checked out good. I took out the battery and Auto Zone tested it and it was fried. I ended up getting my new battery from Batteries Plus for 95.00 ouch. Check on ebay you will get one cheap if that is the route you take.
Good luck
Tom
Old Jun 22, 2010 | 10:02 PM
pollock009's Avatar
well it wont start cuz the fuel pump doesnt kick on ethier
Old Jun 22, 2010 | 10:12 PM
oxyg3ne's Avatar
did you check the Main fuse? the 30A
Old Jun 23, 2010 | 04:59 AM
pollock009's Avatar
yepp all fuses
Old Jun 23, 2010 | 12:08 PM
R Dub's Avatar
October 2011 ROTM
Check your headlight harness where it plugs into the main harness down by the left ram air intake. F4i's are known for the ground wire to corrode and causing the exact problem you are describing. Undo the harness. check all the wires for good solid connection, put dielectric grease on it plug it back together and see if it fires up.
ericling
Jul 26, 2008 08:31 PM
