Plz help-----dropped my bike
ok i know its been awhile due to busy schedule. but i did try to go back to duplicating the issue...................NO LUCK
There goes my season for riding ;(
I checked all wires for cuts and pinching and found nothing. Called honda dealer and they never heard of this problem and quoted me an estimate of $150/hr for diagnostic fee. Knowing the fact they never heard of this issue, im sure they would spend all and charge me arm n leg.
I did discover something new. There are 3 main harness, two of them clips to the gauges and other one to the front piece where all the lights are attached. When the two harness attached to gauges are connected; the gauges works but the bike does not turn on, its just cranks over with the fuel pump not working.
When i do connect the front piece harness; bikes cranks over but the gauges dont work as the fuse blew out.
I dont even know where to go with this.....................def dont want to have t checked by honda since its prob going to be a small fix (i hope).......and they rape me for the bill.
Anyone plz help me.
Anyone plz help me.
Kuro offered to swing by and give u a hand ide take him up on his offer
its def. a grounding issue if ur blowing fuses.... and on top of that it may not be visible when u went down i assume ur bars jerked... any tension on a wire while can cause a internal fracture..... so u may not even be able to see if.... if kuro brings his meter he can help pin point that wire...
