Please help
Old 08-30-2013, 10:13 PM
02-F4i-SuperKax3's Avatar
Question Please help
Hello all, how are you on this fine night?
I am doing my sprockets and chain on my 02 CBR 600 f4i would anyone know what the torque is on all the bolt. On my yzf it was 40 I think
Old 08-31-2013, 07:55 AM
Conrice's Avatar
40 lbs/ft on the front sprocket
47 lbs/ft on the rear sprocket bolts - Make sure to do them in a star pattern.
Welcome to CBRF, I hope you stick around.
Old 08-31-2013, 09:38 AM
Sebastionbear1's Avatar
Welcome to the CBR Forum,
Conrice has given you the good oil on torque for your bolts.
Post some pictures of your bike when you can.
Cheers, SB
Old 09-01-2013, 07:42 AM
I will. Have to Fiberglas work on the tail tabs. Then ill take some pics.
Old 09-01-2013, 10:02 AM
Thanks. Any chance you know the best way to fix tabs on fairings. It's still there but not much holding them on. Was going to use Fiberglas to build it up? Any thoughts ? Tips?
Old 09-01-2013, 10:50 PM
Bryce Swartzwelder's Avatar
Make the tab out of jbweld epoxy putty and then epoxy it on with a stronger epoxy. Make sure to sand the surface clean before you start your work. The putty resists cracking like fiberglass and if it comes lose on one side you can super glue it on it stays it seems.
