Paint
im looking at repainting my bike since i have to fix a crack on the upper cowl and thought i might as well repaint my whole bike. im looking at painting it white because i love the look of white f4i's. but i was just wondering roughly how much does repainting all the fairings cost for those of you who have repainted your bikes?
tooooo many factors.... best bet would be call someone and get a estimate....
alot of people on here do it their selves or know someone else that can help/do it for them....
do u have anyone u know that paints?
are u looking for just paint/clear/primer costs?
or labor costs? lol need some more info
also are u doing all white? or did u plan on putting a wing decal/wing paint on it?
Well it all depends if you are going to do it yourself or if you are going to take it to a shop. If you end up taking it to a shop take off all of your pieces and bring them into the shop that will cut down the cost quite a bit due to the fact that they will probably charge you at least 5 hours labor for taking and putting the pieces off and the on. I will say that a body shop will probably charge any where from 800 to 2000 depending on what kind of paint you get and what kind of theme you are looking to go for.
If you are going to due it yourself it is not that expensive. I spent around 75 bucks on supplies ie. sandpaper some bondo fiberglass(to repair a crack) and some spot primer. Then it was around 350 bucks for my paint and clear coat. If you dont trust yourself painting the bike then I would deff bring it to a shop but if you do trust yourself and have a spot to paint it then I say go for it. Doing it yourself is half the fun and then you can get full satisfaction of what you did yourself.
This is what my bike looks like after I did my paint job.
You forgot to factor in the cost of the compressor and gun.
The most expensive shop in my town estimated $1500 for one color. Another shop I've had work done before estimated $750. From the work I've had done the only thing that makes the other shop so much more expensive is reputation...
Ask around. No one on this forum can tell you how much its going to cost. You have to figure that out for yourself.
Painting a bike is no different than a level 3 model. You just have to have proper prep work.
prep works only half of it....
teko-what color is your bike im just curious
cbrf4i kid-take it to shops and see what they will do, try the ones that might be starting out and need to get there name out there and they might do you bike to get some pics of it. one did that to me it turned out good, i think. its all personal preference. im pretty sure my paint was less than 500 its candied with a marbalized top coat
My bike is still the stock silver/red. Getting ready to either paint it metallic dark charcoal or turn it into a pearl white 848 clone. Learned how to paint plastics in 7th and 8th grade shop class (when it still existed in school). Just don't know if I want to rent the equipment for a weekend or use the aerosol cans from color rite.
Something like this...
Are you kidding me? Prep work is 95% of it.
