Oil Change
Old Aug 1, 2009 | 12:02 AM
phillycbr's Avatar
Default Oil Change
Yes I did search guys. I can't seem to find a thread on doing an oil change. I do my own changes to my car but am clueless when it comes to bikes. So my question is, What type of oil do I use? Where can I get the filter? Is the filter right behind the front tire? Do I need to remove fairings to drain it? Is the bolt the one right on the bottom of the bike?
Thanks.
Old Aug 1, 2009 | 12:15 AM
33andathird's Avatar
oil change on a bike is real, real easy. youtube it. i know there are a few step-by-step videos on there. i didn't remove my fairings on my f4i...filter is right behind the front tire, bolt is on the bottom of the bike. as far as the oil goes, you can go expensive or not. i just went honda 4-stroke 10w-40 (cold weather use 10w-30). heard alot about using synthetic for any mileage over 15,000. really your choice there.
Old Aug 1, 2009 | 03:57 AM
cbrfreak47's Avatar
http://www.shraz.net/motorcycle/f4i/oilandfilter/
very helpful DIY have fun like the last guy said very easy i literally just changed my oil 20mins ago....and just to let you know after you finish the change and you take it for a spin or what not if you see it smoking a little dont be alarmed its justr the oil burning off the headers o yeah have fun hope this helps
Old Aug 1, 2009 | 05:29 AM
FFCBRf4i's Avatar
haha well if you did it well, there will be no oil on the headers. BTW, that site is really helpful for those that need it:
Oh, and don't expect that spark plugs write up to come in any time soon. It's been "coming soon" FOREVER! =]
Old Aug 1, 2009 | 08:00 AM
skoobydoobie's Avatar
Go to wal-mart, get yourself some Shell Rotella T in the blue jug (NOT the white jug) and the filter for a Civic. It'll cost ya a lil over 20 bucks for everything.
Old Aug 1, 2009 | 11:30 AM
2H company's Avatar
Nice write up on that site. +1 for putting foil over the pipes.
Here is another one: http://www.bossturbo.com/cbr/howto_oilchange.shtml
Also, another question. As I know the standard capacity is 3.75 qt of oil. It's recommended to use 3.25, let the engine idle for 2-3 minutes and add another 0.5 qt.
So, is this correct?
Old Aug 1, 2009 | 01:17 PM
Uniqsol's Avatar
The Supertech filter is ST7317. Its about $2.50-$3.00
And the Rotella-T (synthetic - blue jug) is about $19
Also, Keep in mind the ST filter is bigger than the OEM one, so your oil capacity is a little bit more. Just make sure to check your oil level after running the bike for a few minutes.
Old Aug 1, 2009 | 06:44 PM
cbrfreak47's Avatar
Just a quick question if to much oil is put in what's the easiest way to take some out drain a little?? Get a tiny spoon and scoop it out the filler lol
Old Aug 1, 2009 | 07:00 PM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
You can use one of these; stick the tube in the filler hole:
...or you can loosen the drain plug (messy).
Old Aug 1, 2009 | 07:09 PM
mike and ikes's Avatar
That looks like it is designed to extract all the oil without having to pull the drain plug. Am I correct?
That's kind of neat but I would still pull the drain plug after I got all the oil out with the nifty oil suckeroo. Just to be safe. It'd be less messy that way for sure.
