oil?
Old Oct 18, 2008 | 09:55 PM
jlowellb's Avatar
Default oil?
How bad is it to put valvoline Max life sythic blend 10w-40 in a F4i, I know it says to use 4 cycle oil but max life is way cheaper.
I was wondering what you guys use and if anyone else has made such a cheapass decision.
Old Oct 18, 2008 | 10:00 PM
glacier_white_F4i's Avatar
Default RE: oil?
i only use stuff with wet clutch additives in it. valv makes it full synthetic
Old Oct 18, 2008 | 11:54 PM
jlowellb's Avatar
Default RE: oil?
So is the stuff i got in it bad? Do i need to put 4 cycle 10w40 in it? that stuff is like $10 a pop.
Old Oct 19, 2008 | 12:34 AM
Default RE: oil?
it may not be horrible. but it's not made for it. its like running an untuned power commander...it'll work, but not to it's potential. i'd be worried about possible clutch slippage and the way it holds/removes friction material.
Old Oct 19, 2008 | 03:58 AM
Xuracing's Avatar
Default RE: oil?
Don't do it!
Old Oct 19, 2008 | 12:51 PM
usetheffours's Avatar
Default RE: oil?
I am a cheap *** except when it comes to oil. Motorcycle oil lubes the engine, transmission, and the clutch with the same oil. You really need all those parts working. I run amsoil.
Old Oct 19, 2008 | 01:28 PM
A4wheelin's Avatar
Default RE: oil?
ORIGINAL: usetheffours
I agree, I too am a cheap ***. But I will not skimp on oil. It's what makes your engine run smooth. I get the big jug of oil from the dealer. Not sure how much it is. Pretty sure it's cheaper than $10 a quart though.
Old Oct 19, 2008 | 01:32 PM
Stephens's Avatar
Default RE: oil?
Oil is the one thing that will keep your bike running strong. Honda Pro Oil 10W-40 without moly and a K & N oil filter.
Old Oct 19, 2008 | 09:54 PM
jlowellb's Avatar
Default RE: oil?
switch out the oiltoday, I only ran the over stuff for about60 miles.38 bucks for 4 quarts. should I add some lucas? does the fueladditive chemicals work on a bike? Like fuel injector cleaner, etc, etc.
Old Oct 19, 2008 | 10:50 PM
Stephens's Avatar
Default RE: oil?
If you didn't run it long and got it out and got new oil in your bike you should be ok. If you feel your clutch slipping or your bike running really hot, those might be some symptoms. Hondas are built strong as hell, it takes alot to break em down.
