Oil
Old Mar 1, 2008 | 06:03 PM
FosmoenAlex's Avatar
Default Oil
i live way up north where its still freezing, but its coming to that time where i need a tune up, i have had my bike since last year and havent had to do an oil change yet, i know how to change oil, not really brain surgery, but does anyone have any pics of where the drain oil drain plug and the oil filter is? and if i gotta take any plastics off or not, thanks for the help
Old Mar 1, 2008 | 06:06 PM
jaynd's Avatar
Default RE: Oil
some people remove their lowers but i dont....you dont HAVE to, you'll just get a bit of oil on the bottom of them which isnt even noticable unless you're wheeling, lol. the oil filter is easy to see............"if it were a snake, it would'a bit'cha!" lol
the drain plug....a bit harder to explain but you dont have to remove the lowers for that either. its kinda hiding behind the kickstand area.
by the way, how many miles since your last oil change....?
Old Mar 1, 2008 | 06:15 PM
Default RE: Oil
well i bought the bike last july, and the people i bought it from said they had just changed everything so i didnt worry about it, the oil level was fine, and its been sitting since the end of oct
Old Mar 1, 2008 | 06:17 PM
jaynd's Avatar
Default RE: Oil
i change mine every 3k miles.
i ran outside w/ a flashlight so sorry if the pics are of no help....but i tried.
Old Mar 1, 2008 | 06:19 PM
Default RE: Oil
the top pick the drain plug? or they both drain plug? thanks for all your help by the way
Old Mar 1, 2008 | 06:22 PM
jaynd's Avatar
Default RE: Oil
top pic is the oil filter. just stand infront of your bike and look between your two lower fairings. you really cant miss it.
the second is your drain plug. get down and look behind your kickstand/shifter. you should see a bolt facing the ground down there.
Old Mar 1, 2008 | 06:23 PM
Default RE: Oil
ok and one more question, do you know what type of oil and oil filter i need? and i think it 4 qts of oil? to fill back up
Old Mar 1, 2008 | 06:25 PM
jaynd's Avatar
Default RE: Oil
do a search for oil. you'll get different opinions from EVERYONE but just make sure its synthetic motorcycle oil....whatever you do choose. but click the search button and type in "oil" and choose "topics" and search in the "F4i" section.
i personally have been using Motul 10w-40. i HAVE used AMSOIL too....i've not noticed any difference between the two.
Old Mar 1, 2008 | 06:27 PM
jaynd's Avatar
Default RE: Oil
i also prefer to use the K&N oil filter b/c it has a nut on the end to get it off easier....you just use a socket.
as for how MUCH oil, might wanna check your manual if you have one...b/c im not 100% certain. i know its JUST under 4qts. if you get 4qts you should have enough left in that 4th one to buy only 3qts for the next few oil changes.....thats atleast how it is for me.
Old Mar 1, 2008 | 08:22 PM
Stephens's Avatar
Default RE: Oil
The 2001 uses 3.5 quarts. Don't overfill it or you will leak out your gaskets and burn it in the engine.
