oil
That's what I would do:
1. Put bike on a rear stand
2. Let it warm up for a couple of minutes
3. Shut the engine down and let it stay for a few minutes
4. Drain some oil - check the level
5. ... repeat number 4 until you get the level somewhere in the middle in the inspection window.
Good luck!
Good luck!
How do you go about taking just a little bit of oil out? Should I just let it out until it is half way past the little glass piece?
Personally, I like to fill it with oil so that's it's level with the top line. Oil level should be checked with the bike upright (not on the side stand), and always after the engine has been allowed to run a bit.
