odd ticking/clicking sound
Background info: 05 f4i, just crossed 20k.. 17-18k from the previous owner. No problems/issues with it other than i am finally starting to hear the cct.
For the past 2 days when I ride aggressive (accelerate up to say 10-12k rpm) I just generally hit 3rd gear when i let off the gas and let the revs come down not holding the clutch in. Ive noticed this weird ticking/clicking sound as I am decelerating. Doesn't seem to happen with im cruising and riding conservatively.
Anyway, not sure if its in my head, or something just bouncing around, or if some one has had this problem before.. thought I'd get the forum's opinion.
thanks!
thanks!
Simple bud. At the end of your swingarm is to bolts with nuts on them. The bolts are inside the swingarm in fact, by the axle. There are lines on the adjusters. You tighten both sides and that slides your whole wheel back, or forward, tightening or loosening your chain. There is markings on it indicating a good or bad chain. Let me know if you need more info.
