O2 SENSOR ELIMINATOR?
Old Mar 29, 2007 | 05:54 PM
ninetyfivehp's Avatar
Default O2 SENSOR ELIMINATOR?
will the O2 sensor eliminator work on my 06'? i found a two-bros slip-on locally but its for an 01-03. i know my gas milage would decrease if i installed the o2 eliminator but is there also a chance i could foul the plugs since so much more fuel would be dumped in the combustion chamber at or near idle speeds? i don't want to change plugs anytime soon. it looks like a pita. thanks
Old Mar 29, 2007 | 06:45 PM
Tahoe SC's Avatar
Default RE: O2 SENSOR ELIMINATOR?
you'll be fine running an O2 sensor. it only leans out your bike when you're cruising like on a highway. it won't affect idle, etc.
but i would recommend tapping the pipe and running the O2 since there is nothing to gain but MPG to lose
Old Mar 29, 2007 | 06:59 PM
i know you run the eliminator on your bike, thanks Tahoe. cheers bro
Old Mar 29, 2007 | 07:17 PM
Tahoe SC's Avatar
psss...i trade you eliminator about $16-20 for your O2 sensor ~$100...muahahahhaha
Old Mar 30, 2007 | 03:03 AM
02f4iSailor's Avatar
i just bought a yoshi trs carbon fiber slip-on, the dealership ordered it for me and said the 02 sensor really didnt do anything, i have to go in and order the 02 eliminator on monday. how much mpg are we talking bout losing, should i be worried about anything else
Old Mar 30, 2007 | 01:16 PM
Tahoe SC's Avatar
i can't really comment on how much MPG you lose cause when i did it i had the full system and simulator at the same time.
my MPG went from 40s to about 31...so it's pretty significant with f/s and simulator.
if you do a lot of stop and go, etc...then it won't make much difference, but if you do a lot of highway riding, then it will make a difference since that's when the O2 signals the ECU to lean out.
Old Mar 30, 2007 | 02:52 PM
thanks tahoe
Jeffy_2010
Feb 21, 2012 11:09 PM
Maddawg777
Jun 29, 2010 01:15 PM
tukan
May 26, 2010 07:26 AM
romano007
Mar 7, 2008 05:13 AM
timbo
Jun 28, 2006 04:05 PM
