-   F4i - Main Forum (https://cbrforum.com/forum/f4i-main-forum-11/)
-   -   O2 SENSOR ELIMINATOR? (https://cbrforum.com/forum/f4i-main-forum-11/o2-sensor-eliminator-34759/)
ninetyfivehp Mar 29, 2007 05:54 PM
will the O2 sensor eliminator work on my 06'? i found a two-bros slip-on locally but its for an 01-03. i know my gas milage would decrease if i installed the o2 eliminator but is there also a chance i could foul the plugs since so much more fuel would be dumped in the combustion chamber at or near idle speeds? i don't want to change plugs anytime soon. it looks like a pita. thanks
Tahoe SC Mar 29, 2007 06:45 PM
RE: O2 SENSOR ELIMINATOR?
you'll be fine running an O2 sensor. it only leans out your bike when you're cruising like on a highway. it won't affect idle, etc.
but i would recommend tapping the pipe and running the O2 since there is nothing to gain but MPG to lose
ninetyfivehp Mar 29, 2007 06:59 PM
i know you run the eliminator on your bike, thanks Tahoe. cheers bro
Tahoe SC Mar 29, 2007 07:17 PM
psss...i trade you eliminator about $16-20 for your O2 sensor ~$100...muahahahhaha
02f4iSailor Mar 30, 2007 03:03 AM
i just bought a yoshi trs carbon fiber slip-on, the dealership ordered it for me and said the 02 sensor really didnt do anything, i have to go in and order the 02 eliminator on monday. how much mpg are we talking bout losing, should i be worried about anything elsehttps://cbrforum.com/micons/m5.gif
Tahoe SC Mar 30, 2007 01:16 PM
i can't really comment on how much MPG you lose cause when i did it i had the full system and simulator at the same time.
my MPG went from 40s to about 31...so it's pretty significant with f/s and simulator.
if you do a lot of stop and go, etc...then it won't make much difference, but if you do a lot of highway riding, then it will make a difference since that's when the O2 signals the ECU to lean out.
02f4iSailor Mar 30, 2007 02:52 PM
thanks tahoehttps://cbrforum.com/micons/m9.gif
