Not Starting?
i tried to search but i failed for some reason lol but.....
My 02 f4i wont start it will prime and i can hear it when i turn the key on but when i press the start button the lights turn off like normal but no start? i checkd the fuses and all are good and all wires look fine .... any suggestions?? thanks guys |
Is it even turning over? More information would be helpful.
Originally Posted by teko1020
(Post 879997)
i know its obvious but make sure you have a decent battery in it...if it doesnt even try my vote would be your battery has enough power for the lights/gauges but not the starter motor...hook a voltmeter and check should be around 12v i believe but correct me if i am wrong
Originally Posted by silverstonef4i
(Post 880006)
not being a smartazz because I've done it, but is your kill switch on the right side flipped?? I sat one day for probably 2-3 minutes wondering what the fock happened to my bike, and was even contemplating push starting it, but then saw I had bumped my kill switch. Yeah I felt like an idiot.
hahha no i checked that already
How long has it been sittin. If your battery is good, then its proly hydrolocked. Which means your FPR proly failed and let fuel fill the combustion chamber. (unless it fell over and layed on its side for a while, then the oil may have filled the chamber) But either way, to fix it you will need to remove the spark plugs cover the holes with a rag (to prevent a big mess) and hit the starter button. That will blow all the sht outta the chamber and allow the motor to spin again. Reassemble and rock n f'in roll. Thats IF the battery is not the problem.
Yeah Bro, I have the same problem as well. I have my bike in the garage right now and about every 4-5 days I would go in and start it. The other day, I went to start it, but nothing. I do think it is my battery, but I had it charging, so I am not sure. I am going to buy a new battery and try that first. This time I am go to keep it in my house this time.
Originally Posted by skoobydoobie
(Post 880367)
There is a really nice how to write up by flyou on how to change it with pictures and everything.:icon_teeth: |
