Is this noise something to be worried about?
I hate to be one of those people but my 2005 F4i has a slight "tick" at low rpm's specifically idle-3,000rpms.
The bike has 7,000 miles on it and I replaced the CCTL about 1,000 miles ago when I heard it going bad so I don't think the CCTL is the problem. Any help is much appreciated. Heres the video of the noise, it can be heard very well between 0:30-0:36 seconds. http://www.youtube.com/watch?v=oGanLdtndaA |
Can't hear a tick sound.....
Originally Posted by kazspeed
(Post 1025854)
i hear it, when have you changed the spark plugs?
Originally Posted by backyardmechanic
(Post 1025881)
When you hear the tick, try to pull the clutch in neutral. If it fades away, it probably is your clutch basket
Starts & sounds awful! Perhaps its the cct?
Originally Posted by Slick 6
(Post 1025900)
Originally Posted by Tommysf4i
(Post 1025907)
I have a 2006 and it does the same thing i thought maybe valve shims bc i juts changed the cam chain tensioner to a manual one so i know its not that i even tried running premium gas to see if it was a spark knock and that didnt help so i thought it was valve shims or just a normal f4i sound bc it doesnt get worse at higher rpms
Originally Posted by hites87
(Post 1025989)
I'm beginning to think that it may be a loose spark plug or spark plug wire as someone mentioned before. |
