Newbie Riding Question
Wassup everybody! I'm a new owner of a 2002 F4i and a first rider also. I haven't been able to get in the MSF class yet, so I'm just riding around my neighborhood with my permit. I have a couple questions for you all.
1. When I'm riding and I let go of the clutch and the throttle, I notice the bike starts so slow down a lot faster, why doesn't it coast? I notice if I hold the clutch and let go of the throttle, then the bike coasts like its in neutral. Am I supposed to hold the clutch to coast?
2. How can I get a smooth takeoff in first gear. I'm not comfortable at turning left into traffic.
RE: Newbie Riding Question
What you're are experiencing is called "engine braking". The engine compression is slowing down the bike. When you have the clutch engaged, there is no power the the back wheel, and it will coast.
You just have to ride and get used to the bike for smooth take offs...turns will get better as well. Give it time, and you will be fine. Get to that class as soon as you can!!!
with the clutch out the wheel is connected to the motor is it will slow down. when you pull the clutch in its like releasing it so the wheels spin freely. also for turning left you need to use your left hand and hold the clutch while gassing, and let the clutch out slowly and maybe hold it throug the turn. i had the same problems. you just need to learn how to get into first gear good then everythign else is cake. im a newbie just started last month. you need to take MSF, asap, and get frame sliders
