New purchase with electrical issues.
Old May 4, 2022 | 03:00 PM
gillers's Avatar
Default New purchase with electrical issues.
Hi All, Just got a 2003 f4i. Mechanically excellent but has electrical issues. Went for a ride - did about 20 miles and it stopped. The battery was fried, hot and bulging. A mate put another battery on it and the bike fired up great - charging at 14.3v. Off to home but fried his battery as well so I owe him one. Anyone any idea of the problem. I am assuming a reg/rectifier problem as I have heard there can be a problem with them and an upgraded one can cure the problem? In addition, the headlights sometimes come on with the switch and then maybe not - dirty switch or is this another known problem? Before ripping the wiring apart, any ideas what could be the problem? Just going to look for a manual so I can check the relevant wires etc, hopefully this will give me some clues but members knowledge is always better.. Many thanks for any idea's. Peter
Old May 4, 2022 | 04:23 PM
Hi and welcome to the forum. The R/R is a good place to start. I'd put a meter on it and see what the voltage does while riding. Nothing wrong with 14.3, but if it climbs at higher RPM's, then R/R is likely the issue.
Old May 4, 2022 | 09:21 PM
cbrbike's Avatar
hi. i think bulged battery is usually caused by overcharging. how long did you check the charging ? i would suggest to check charging in different RPM ranges for a couple of minutes.
it could be a dirty switch. you can spray some contact cleaner there and check if it works well.
dilutee
Sep 8, 2012 10:33 AM
bicklebok
Jul 8, 2012 01:32 PM
HKchucksta
Sep 2, 2009 10:29 PM
michaelsbt
May 13, 2009 09:20 PM
bren1422
Sep 9, 2006 07:30 PM
