New OEM or manual Cam chain tensioner ?
Greetings! I have a 02 f4i sport that has a rattling cct noise. I am wondering if it's worth getting a new OEM cct or an ebay manual tensioner ? Taking into consideration the fact that the manual is a third of the oem one's price, I would like to know how much will the oem one last before it starts rattling again. Also how often do you guys with manual tensioners adjust them ? Thanks and have a good day!
My original lasted a bit over 15,000 miles before I could hear it. I ran it another 1,000 miles or so before changing it out and went with another oem one. I did plan on putting a manual one on a few months ago when I had the bike torn down to do the valves but ended up not doing it. I like the idea of having one that can self-adjust and don't mind switching it out every couple of years.
That being said, from reading past threads it seems most here prefer the manual one...
I have the APE manual tensioner installed on mine.
Ive adjusted mine twice over the last 3 years, once when installed , then again a little over a year later.
From what Ive read in the past the OEM tensioner is a little unpredictable in terms of life span.
A heads up though, it takes patients to get at this thing to adjust it. There isn't exactly a lot of room to play with. But Ive had no issues or regrets with about 25,000 kms on it so far.
Just remember that over tightening is a real possibility with these , you can hear when youve gone too far, it almost gets what sounds like a supercharger whine to it , doing damage never sounded so cool lol.
But with a little back and forth you'll get it dialed in pretty easily, just error on the side of caution if your not sure, better a little loose than too tight.
The following users liked this post:
Doc Samson (03-11-2020)
