new grips
Old Mar 5, 2008 | 06:03 PM
RooR Mast3r904's Avatar
Default new grips
Ok so this weekend i went out to cycle gear and saw some grips i really like. Took old ones of put on the new ones and did everything it said and gave it a day to dry. But the dont srick like the move around and is very annoying on my throttle hand and have to keep adjusting it. Just wondering if their is any glue i can buy or anything. let me know thanks.
P.S. i lost a bar end on the ride home to day[:@]
Old Mar 5, 2008 | 06:39 PM
traitorhound's Avatar
Default RE: new grips
Safety wire the grips on. Granted I've never really had any problems with grips sliding until I started using grip heaters under the grips.
Old Mar 5, 2008 | 08:04 PM
TBFGhost's Avatar
Cycle Gear you say? How do you like the one by you?
Old Mar 5, 2008 | 08:05 PM
oodayvidoo's Avatar
wut kind of grips did you get? i got a pair for ProGrips and they work fine. i didn't even let them try for a day... just 15 minutes and i was good to ride. did you use anything to slip them on/off? try windex to slip off/on again maybe that mite bring back that adhesive or wutever is leftover on the handlebar
Old Mar 5, 2008 | 10:02 PM
Icefox's Avatar
Did you use any grip glue at all the first time you tried to install them? I know you said you gave it a day to dry, but I wasn't sure if there was any glue involved or if you were letting something you used to slip them on dry. Make sure the throttle tube is clean when you put them on, and yes there is grip glue, some are even brand specific because of the rubber compunds they use in the grips. Spraypaint also works as a type of grip glue as well, just make sure the throttle tube is clean and give it a little shot of spraypaintinside the grip and slide her on! Safety wire will also help them stay put like traitorhound suggested, and will be pretty easy to do...especially if you know someone with a pair of the handy safety wire pliers!
Old Mar 5, 2008 | 10:20 PM
Jump1979man's Avatar
use hairspray.
Old Mar 6, 2008 | 08:46 AM
ffingers's Avatar
Registered Users
^ ++1 hairspray...a natural adhesive...IF...that doesn't work...there is grip glue... http://www.speedsupplies.com/accesso...asp?item=12361
Old Mar 6, 2008 | 01:07 PM
devlzluv's Avatar
ya agreed use hairspray then grip glue. grip glue is very fun to use lol, goes on very easy with the glue but a pain in the *** if you ever have to take it off
Old Mar 6, 2008 | 01:10 PM
jdschmidt's Avatar
yep, i had the same problem..a little hairspray took care of that..and you dont have to sit and watch it dry for a day..i was off and riding again in like 20 minutes..and it stuck just fine.
Old Mar 6, 2008 | 08:18 PM
Thanks will try hair spray tonight. And yes i like the cycle gear buy me. Met a couple guys in thier and are pretty good friends thinking about getting a second job thier to help pay for future mods. thanks for the help guys.
