New Brake Pads
a "bedding in" of the pads and rotors. This is a cycle of hard stops without coming to a complete stop. I believe but dont quote me that you want to do a series of 10 hard stops but not completely. Start with a 60-70 mph hard brake to about 10-20 mph and get back up to speed quickly and do this again. Maybe towards the 8-10th stop reduce the top speed to about 40-50 mph.
This is a good process to follow in your car..it ensures the longest life of the pad, and the least chance the brakes will eventually start squeaking. In a motorcycle however I doubt it is very important, and i doubt you would have been able to glaze the pads making hard stops from 70mph right after you put them on, being that the bike only weighs 400 lbs and the brakes run so much cooler than in a car. I just didn't want this misinformation floating around and cause anyone any problems for their next brake job on their car
^^ looks like he did for me... the website where flyou found his write up is talking about slamming on brand new brake pads until you can smell the brakes and/or see smoke...that would sound to me like they are being heated well past where they should be (especially brand new). I'm sure there are plenty of pads more designed for racing (carbon metallics and such), however, that would fare perfectly fine following those instructions. However I would never recommend bedding the vast majority of pads by slamming on your brand new brake pads from high rates of speed until you feel them fading, see them smoking, and smell them, as the write up says to do.
ORIGINAL: dwschultzy
Looks to me as the objective of both procedures of "bedding" the brakes is to allow the pads to apply a layer of material to the rotor.
I believe that all disc brake type brakes have drag to them causing this slight grinding noise. You probably dont notice this on your cage due to the fact that there are obstructions between you and the brakes. I have installed multiple disk brake conversions on my air-cooled vw's and every single kit has had this drag.
