need help removing tail fairings...
Its also attached to your undertail from the bottom, then those two that are sticking out and two next to the tank. After that you just kinda have to play with it to get it ou from your subframe.
i would take the seats out it makes it easier to wiggle it off..just make sure to not pull apart the sides of the tail to much or you might crack your paint or damage the fairing...
