need help please
i have a cbr 600 f sport from 2002 i've changed the spark plugs and it starts i ride it tot and when i was on the street my tachometer started to go crazy and the exaust popped out..........and now wont start anymore
help me please
help me please
Last edited by 74demon; Feb 9, 2013 at 10:39 AM. Reason: threadjack,started own thread
Could you elaborate on the "won't start anymore." Does it crank over? Is the battery dead? Did it act like this before the plugs were changed? Has it ran fine since they were changed?
I suspect you have battery/charging system problems. Do you have the right tools to check the system?
The F4i has a coil for each plug. There are no wires to cross. But there could be an issue with the electrical plugs on the coils. If your problems started right after a plug change, retrace your steps.
i don't think he would be able to make it out the driveway if the firing order was wrong, but yea, retrace your steps if the issue was not there before you changed the plugs, seems like a brain-fart error on your part if it was ok before
yes after i've changed the spark plugs i started it and used the bike,my bike actually made this problems before i change spark plugs and it smells gas like it didn't burn....the wires are in a correct order because it's writed also on the motor the order i have to plug them.....can it be a fuse or something because when i try to start it it's spins but won't start.....appreciate your help
