need answer asap
RE: need answers asap
ok...last question about this....
when you set the peice of the stabalizer on there that bolts to the triple tree, it has a little bit of play back and forth...in other words, theres to tabs that come off of that peice to make it so you couldnt put it on backwards....are those two tabs supposed to be snug against the triple tree...because when i put it on theres maybe a 1/8" play back and forth between each tab hitting the triple tree....is it supposed to be like that?
did anyone understand that?
if I understand your question correctly then look on the black part next to the tank, there are two pinch bolts with allen heads on them that you tighten to fit snug against the tripple so it doesn't move let me see if I can get a pic up of it
is that what your talking about though?
here is a pic of what I think your looking for:
http://img389.imageshack.us/img389/8269/pinch21bd.jpg
