my new artfibras undertail
#53
Phil11,
For the tail light, there are 2 tabs by taillight hole. I bent then straight up and then put the 2 bolts on the taillight through the U-shaped parts of the tabs on the undertail.
As for mounting the undertail, I had to drill 4 holes on the bottom where there are holes in the tail fairing that the plastic rivets go through. Then I had to drill 1 hole on each side of the cargo area at the very end of the subframe where the bolts go in from the inside. Then, I had to make a long L-shaped bracket for the battery try that mounts under the tank bolts.
It's hard to describe it all from words, so I will try to take a few pictures tonight and update the first post with them.
#55
