My Height ?
#21
#23
#24
RE: My Height ?
well the bike is only a few inches from the ground as it is. Hitting a bump or train tracks or a lowered bike isn't going to be fun. You also lose handling when you lower the bike. Quite a bit from what I hear. The bike is perfect as it is. It's not like when you lower a car and it makes it handle better... These bikes are engineered and tuned to near perfection, IMO.
#26
RE: My Height ?
lowering a bike is not a bad thing, as long as it is not lowered severly. the key is the lower both the front and rear the exact same amount, gotta keep stock geometry. lowering too much can cause clearance issues with the lower fairing, but i believe that severe lowing has more effect on suspension action. the shock gets into some really odd angles and cannot work as well. the only clearance issue that i could see is that your pegs are lower and will scrape sooner.
that being said, you can send your stock suspension off to any good suspension shop and have lower fork springs and shock spring installed and all the proper valving put in. if you lower the cheap way, remember to adjust your stock stuff stiffer to help with the bottoming issue.
this is all just my opinion, ive never lowered a bike, ridden a lowered bike, and personally dont care for the look. im 6'0, i need a lift kit!
#27
#28
RE: My Height ?
ORIGINAL: 01600F4i
Agree...also it changes the whole set up of the bike. Want to throw off the way you take turns, get your bike lowered...I tried riding my friend's F4i that was lowered 3 inches and it was so ****ty.
#29
RE: My Height ?
ORIGINAL: virtualbong
I've been hearing some people say this, but no one explains why. Can you give us an explanation? I know it would at least help me out since I'm new to biking as well.
ORIGINAL: 01600F4i
lowering the bike sucks. Don't do that.
Firstly, I'm 5'3" with a 28" inseam. I'm an F'in dwarf LOL.
My previous bike was a 97 F3. I had some money to burn so I toyed with the idea of lowering my bike. I've been one-footing my bikes for over 20 years but thought this may give me some inspired confidence. I lowered it about 1.5" in both front and rear with RaceTech components.
On the street (e.g. commuting, tooling around town), it was fine but you have to watch out for the speed bumps and weird driveways. In the twisties, it was fine too. No real issues. But then again, I don't ride the twisties very hard.....that's what the track is for.
On the track, it was okay. The lower center of gravity made it more flickable. That part was cool. But then my skills got a lot better. I was then scraping fairings on the turns at really hard lean angles. That's not good!
After that, I raised it back up to stock height and even raised the rear even higher with an aftermarket shock. So I was back to one-footing. But I've been doing that for over 20 years of riding so I'm used to that.
So can it be lowered? Yes.
Should it be lowered? That is the better question. It'll really depend on how your ride. My recommendation....don't lower it if you plan to ride aggressively (mainly this applies to track riders). Otherwise, you'll be okay but be careful with certain road hazards.
there are many ways to lower. Some are better than others (I personally hate the way dog bones affect teh suspension performance). Some are cheaper than others. As with anything, its about tradeoffs. Here is a post I made about lowering:
http://forums.cbrworld.net/forums/162531/ShowPost.aspx
ORIGINAL: 01600F4i
ORIGINAL: 01600F4i
#30
RE: My Height ?
ORIGINAL: pitsvtec
ORIGINAL: 01600F4i
