My 2001 CBR 600 F4i build
Old Dec 5, 2010 | 02:03 AM
LasVegasHarley's Avatar
Default My 2001 CBR 600 F4i build
I just bought this 2001 CBR 600 F4i on 11/27/10 for $900. It had been sitting for over a year. The bike had bad fuel, a bad fuel pressure regulator, a seized fuel pump, some broken fairings and a slightly bent rear wheel.
I drained the tank and cleaned it with sea foam and a lot of elbow grease.
I then bench tested the fuel pump and found it was seized. So I called the stealership and got a price $510.00 for a new pump, (I politely said "No Thanks"). I decided to take the pump motor apart and get a look at the guts and clean everything then reassemble. I got that running like new. I bought an automotive fuel filter and for $8.00 and that was that.
Next I pulled the plugs which looked pretty good so I cleaned and gapped them. Started the bike up and it was WAY TOO rich so I checked the fuel pressure regulator vacuum hose and (you guessed it) it was wet with fuel. had to bite the bullet and pay the local Honda dealer for a new one $80 plus tax.
I figured while I was at it I might as well clean the injectors by pressuring them up one at a time with carb cleaner and opening them with a 12v jump pack. they all flowed very nicely after cleaning.
So anyhow she is running great now. I got her registered and insured and went for a ride today (that's when I learned of the bent wheel).
I bought a used set of wheels on craigslist for $120 this afternoon they are pretty ugly so I am painting the rear Gloss Black right now.
I like the bike a lot and will buy fairings after Christmas from Delkevic.
...more to come.
Here are some pics for your enjoyment/boredom:
Old Dec 5, 2010 | 02:07 AM
jp_greenville13's Avatar
Good buy!
Old Dec 5, 2010 | 02:09 AM
and you got it on my birthday! double good buy!
Old Dec 5, 2010 | 02:20 AM
Thanks jp_greenvile13! I forgot to add that I got a battery from Batteries Plus that was an exact fit for only $54.00. So my running total is:
900.00 bike
10.00 seafoam
8.00 fuel filter
80.00 Fuel pressure regulator
54.00 Battery
120.00 wheels
-120.00 for the wheels that did not work out (f4 wheels, bike is f4i)
107.00 Used rear wheel on fleabay
37.00 Sintered brake pads (all six pads)
246.00 Tires Bridgstone BT-016 front and rear
23.00 Fresh oil (Rotela T6 synthetic and Super tech filter)
10.00 Turn signals (harbor freight)
$1475.00 total
Old Dec 5, 2010 | 02:23 AM
Zero1080's Avatar
Ok, that being said, I'll buy it from your for 1500.
If you so choose not to, welcome to the site
Old Dec 5, 2010 | 02:40 AM
wattufaka's Avatar
Bravo! Why does it seem that the bikes that are resurrected always silver? lol just like mine. Hows the chain and sprockets? Can't tell form your pics.
Old Dec 5, 2010 | 03:52 AM
The chain and sprockets are brand new! 520 chain is that stock for this bike?
47 teeth in back. I have not yet checked the front sprocket.
Old Dec 5, 2010 | 12:13 PM
MitchA's Avatar
Darn, thought I had the deal of the year. $900 is a terrific bargain with that low repair costs. I hope you have as much enjoyment as Im having with mine.
Old Dec 5, 2010 | 06:08 PM
speedyf4i's Avatar
i believe stock gearing is 16 front and 46 rear
Old Dec 5, 2010 | 10:00 PM
600F4inoober's Avatar
Your gearing is not stock. Stock is 16/46 with a 525 chain. Your chain and sprocket(s) are aftermarket
Edt: Just noticed the rear sprocket is black which is also a giveaway...
