My 01 f4i Project. Few questions...(electrical,VSS)
Whats up fellas, well lemme first start by I decided to take my recently purchased stunt bike and make it just something i can save gas and putt around on. Heres how it started..
Heres how it looks now after painting the frame and lowering.
Soo I was missing alot of wiring, so i just put a new main harness on, and clip ons.. Im in the process of trying to figure out the rear wiring, my question is I dont have the front headlight harness on and i belive that has a turn signal relay built in?? would that be why i try to turn the turn signals on and it doesnt show it flashing or even show that i have a turn signal on.. not getting any volts to the rear where i think i should have power for signals..
Next question is the speed sensor.. Its not working,I found this..
http://en.allexperts.com/q/Motorcycl...er-working.htm
Tried that, no power there so i checked right off the sensor, theres 3 wires, black i was reading 12v, green 0, pink 2.4 volts.. id spin the front sprocket and it never changed... what you think?
ALSO looking for a passenger peg set, like bracket and everything... If you got a set let me know.. May also be looking for front headlight wiring harness, I got a harness off stunt;life and the guy sent me a front fairing stay, hopefully it was a mistake.
THANKS fellas
THANKS fellas
